John Deere 1020 Tractor Stalls after two minutes
   / John Deere 1020 Tractor Stalls after two minutes
Still struggling.
I have rebuilt the carburetor, pulled the gas tank and cleaned it, put in an inline fuel filter, pulled the radiator and flushed it (ordered a new one).
The tractor started yesterday and I ran it up and down a hill for about half an hour, thought it was good. The temp gauge sat at about the middle so it did not appear to be overheating.
Eventually died sounding like it was out of gas. Added gas now it will start strongly run for a few moments and die, will start if I pull the choke but dies within a few minutes.
Gas, Spark and Air - I am at a loss.
   / John Deere 1020 Tractor Stalls after two minutes #12
Is the carburetor float set correctly? Sounds like the needle seat isn't opening enough or the float could have a pinhole in it. That would cause the float to drop and cause it to flood (too much gas). To check that, pull the carb apart again and shake the float. If it has a hole the float will be full of gas and you'll feel it when you shake it.
   / John Deere 1020 Tractor Stalls after two minutes #13
Another thing that happened on my old JD 14SB (don't know whether it'll apply in your case) was an overhead valve pushrod had gotten out of its position. It had basically jumped out of a ball at the base of it, making it a tight fit against the valve lifter. So, when it got slightly hot (a couple minutes or so), it made the valve leak, and the engine quit.
Could have the same thing happening if the valves are just too tight, e.g. have no clearances.
Ralph
   / John Deere 1020 Tractor Stalls after two minutes #14
did you ever resolve your problem? i have a similar issue with a JD 301a
Show Livestock Double Blower Stand and Fan Stand (A50515)
Show Livestock...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
43002 (A51691)
43002 (A51691)
2016 Chevrolet Cruze (A50324)
2016 Chevrolet...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
