John Deere 1020 No Spark
   / John Deere 1020 No Spark #1
lanceb36
Port Orchard, WA
John Deere 1020
I have been having trouble with my John Deere 1020 Type 14R1C Serial 066038T. Current issue is it will not start with no spark.
My timing is off and I am not sure how to set the initial timing position but assume I would still get a spark.
I have 12 V on the positive side of the coil (with or without the key on). I have the red and black from an electronic ignition module (replaced points) and a bundle of three wires going to the positive side of the coil. Is it possible that I have ruined an electronic ignition module? Any way to test this?
I have three coils and have traded them in an out but am doubtful that they have all gone bad.
Not sure my wiring is all correct in the battery compartment behind the dash. Beyond the ignition switch is there anything essential to starting in the wiring behind the dash?
Lanced
   / John Deere 1020 No Spark #2
I am afraid I don't have any experience with the aftermarket electronic ignition kits for these tractors. But, I can't imagine you should have 12 volts to positive side of coil with they key in off position. One wire to positive side should go to switch. Second wire should go to starter solenoid. I am assuming the third must be for the electronic ignition. You need to figure out which wire is feeding the 12 volts with key off. COuld be a bad switch, starter solenoid, or ignition module.
   / John Deere 1020 No Spark #3
Maybe time to get the service technical manual for the 1020. Should have some test procedures in there.
But hang tight, as there are very knowledgeable members here who can get you some help too.
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2023 Ram 4x4 Pickup Truck Bed (A49461)
2023 Ram 4x4...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A51039)
2019 Energreen EVO...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
