John Deere 1020 No Spark
   / John Deere 1020 No Spark #1
lanceb36
Port Orchard, WA
John Deere 1020
I have been having trouble with my John Deere 1020 Type 14R1C Serial 066038T. Current issue is it will not start with no spark.
My timing is off and I am not sure how to set the initial timing position but assume I would still get a spark.
I have 12 V on the positive side of the coil (with or without the key on). I have the red and black from an electronic ignition module (replaced points) and a bundle of three wires going to the positive side of the coil. Is it possible that I have ruined an electronic ignition module? Any way to test this?
I have three coils and have traded them in an out but am doubtful that they have all gone bad.
Not sure my wiring is all correct in the battery compartment behind the dash. Beyond the ignition switch is there anything essential to starting in the wiring behind the dash?
Lanced
   / John Deere 1020 No Spark #2
I am afraid I don't have any experience with the aftermarket electronic ignition kits for these tractors. But, I can't imagine you should have 12 volts to positive side of coil with they key in off position. One wire to positive side should go to switch. Second wire should go to starter solenoid. I am assuming the third must be for the electronic ignition. You need to figure out which wire is feeding the 12 volts with key off. COuld be a bad switch, starter solenoid, or ignition module.
   / John Deere 1020 No Spark #3
Maybe time to get the service technical manual for the 1020. Should have some test procedures in there.
But hang tight, as there are very knowledgeable members here who can get you some help too.
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
66in Light Material Bucket Skid Steer Connection (A52128)
66in Light...
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
2013 Ford E-250 Cargo m (A50323)
2013 Ford E-250...
