John Deere 1020 No Spark
   / John Deere 1020 No Spark #1
lanceb36
Port Orchard, WA
John Deere 1020
I have been having trouble with my John Deere 1020 Type 14R1C Serial 066038T. Current issue is it will not start with no spark.
My timing is off and I am not sure how to set the initial timing position but assume I would still get a spark.
I have 12 V on the positive side of the coil (with or without the key on). I have the red and black from an electronic ignition module (replaced points) and a bundle of three wires going to the positive side of the coil. Is it possible that I have ruined an electronic ignition module? Any way to test this?
I have three coils and have traded them in an out but am doubtful that they have all gone bad.
Not sure my wiring is all correct in the battery compartment behind the dash. Beyond the ignition switch is there anything essential to starting in the wiring behind the dash?
Lanced
   / John Deere 1020 No Spark #2
I am afraid I don't have any experience with the aftermarket electronic ignition kits for these tractors. But, I can't imagine you should have 12 volts to positive side of coil with they key in off position. One wire to positive side should go to switch. Second wire should go to starter solenoid. I am assuming the third must be for the electronic ignition. You need to figure out which wire is feeding the 12 volts with key off. COuld be a bad switch, starter solenoid, or ignition module.
   / John Deere 1020 No Spark #3
Maybe time to get the service technical manual for the 1020. Should have some test procedures in there.
But hang tight, as there are very knowledgeable members here who can get you some help too.
Stump Grab Bucket (A50322)
Stump Grab Bucket...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
Genie GTH-644 (A50490)
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
