John deer 4700 shifting
   / John deer 4700 shifting #11
I would check on getting the pump repaired rather than replaced. There are several injector pump shops in E TX.
   / John deer 4700 shifting #12
I find it hard to believe that a bad injector pump would only affect 1 cylinder. There's only 1 pump, it either works or it doesn't. Perhaps the fuel line to that one cylinder is plugged? Maybe that 1 cylinder has bad compression?
How did they determine this? I'd want more details on a repair that expensive before I did it.
I finally go back to work on my 4700. Checked the plungers in the injector pump , when is was clogged up and I loosened it a while back I must have pushed the 3 cylinder plunger out of line .
The vertical plunjer canal was not in one with the rest, so the 3 rd cylinder alway stayed in the shut off position or low idle.
I took the plunger guide out with a magnet loosened the clamp trough the side opening, rotated the plunger so it is in line with the other 3 and tractor runs good again! Thanks for everybodies input!
   / John deer 4700 shifting #14
Good deal:thumbsup:
TASK FORCE TABLE SAW W/ STAND (A58374)
TASK FORCE TABLE...
Trailmobile Van Trailer (A56435)
Trailmobile Van...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56435)
2002 Chevrolet...
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
Harley Davidson (A56859)
Harley Davidson...
