john 535
/ john 535 #1
bpmn
tn
kubota m9540
john deere 535 round bale bale monitor the gauges that are for keeping bale even on both .cant get to work any ideas
/ john 535 #2
:welcome:
Do you have 12 volt negative ground power to the monitor? Do you have electrical plug connected snugly & correctly between tractor & baler? Have you regularly greased the activating arms with the brgs on the rear of baler?:
/ john 535
ye yes no to last one. the green and yellow and red light work. so I know its hook up right. just cant get arrows to move at all. I will grease and see
/ john 535 #4
Sorry but just because the green,yellow & red lights operate correctly is no indication that you have POLARITY attached to battery correctly. 12 volt lights will glow on + or - ground system.
/ john 535
thanks .you were right about wiring on jd 535 bale trac moniter. I switched them and the gauges worked
/ john 535 #6
Thanks for update. I'm glad you got it sorted out
Jim
2016 Nissan Versa Sedan (A64557)
2016 Nissan Versa...
2016 FORD E450 SHUTTLE BUS (A67148)
2016 FORD E450...
Kubota L2501D 4x4 Utility Tractor with Land Pride 72in Brush Cutter (A64553)
Kubota L2501D 4x4...
2012 Ford F-450 4x4 Liftmoore 1640 4,000lb. Crane Service Truck (A64556)
2012 Ford F-450...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
