Jogn Deere Stabilizer/sway bar question.
   / Jogn Deere Stabilizer/sway bar question. #11
It's not normal for sway bar brackets be attached to draft links 180° opposite. As I previously stated RH sway bar bracket needs to have nut loosened & bracket rotated 180° so both sway bar brackets are attached the same way on each draft arm then nut tightened. Notice green area on mounting brackets in photo. This falls under correct geometry of sway bar attaching parts!!!!!!!!!
   / Jogn Deere Stabilizer/sway bar question. #12
Ayep!! If you want symmetry, you have make things symmetrical side to side.
   / Jogn Deere Stabilizer/sway bar question. #13
It's not normal for sway bar brackets be attached to draft links 180° opposite. As I previously stated RH sway bar bracket needs to have nut loosened & bracket rotated 180° so both sway bar brackets are attached the same way on each draft arm then nut tightened. Notice green area on mounting brackets in photo. This falls under correct geometry of sway bar attaching parts!!!!!!!!! View attachment 3221684
Tx Jim, I didn't see what you meant - the first time you said it - I sure do see what you meant now though! You are correct for sure, that bracket being 180 out will cause exactly the problem the OP is having. Thanks for reshowing these pics, cleared up any confusion I had!
   / Jogn Deere Stabilizer/sway bar question. #14
You're welcome.
I'm glad you realized what I was stating was correct.
2017 Rogator RG1300B Dry Fertilizer Applicator (A51039)
2017 Rogator...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A51039)
NEW 2024 LOAD...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Lowboy Trailer (A49461)
2019 Fontaine...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
