Joe H MF 50 hoe
/ Joe H MF 50 hoe #1
Dieseltech
Akron, IN
MF 85 diesel, TO 35 diesel, 165 diesel, IH Hydro 84 diesel, MF Super 90 diesel puller, Agri Power 7000, 8000, and 9000 diesels, MF 205 diesel
Found spec sheet for your injection pump 3340F000, has 3 possible fuel setting codes, 49/900/3/2310, 52/900/3/2310, or 57/900/3/2310. At your altitude I hope code on your tag is 49 or 52, I know 57 will probably have some smoke. Here where I am in IN about 900 ft some MF tractors are OK with 63 cc fuel code which is on MF 175-180 with 236 engine. Looked up injector tip # also, calls for BDLL150S6705 for your engine, tip needs to be removed to see # though. Have another thing that should be checked, make sure air inlet TO air cleaner is not blocked by some rodent nest, can quick check this with both air filters removed to test. If smoke trouble clears with filters out inlet is blocked into can assembly. If you like call 574 893 4172 after 7PM IN time, be glad to help if I can.
2025 MMS MS36C (A60463)
2025 MMS MS36C...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
Takeuchi TB290 (A60462)
Takeuchi TB290...
International S1900 (A61307)
International...
