Jinma Shuttle Shift
/ Jinma Shuttle Shift #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
I have a 06/07 Jinma 254 with the creeper gear that I never use and since I now have a Coldwater loader the shuttle shift option would be nice. I was wondering if it was worth putting a shuttle shift in and if so how much would it cost? I would guess I would have to split the tractor and take out the creeper gear.
Thanks,
Ash
/ Jinma Shuttle Shift #2
I think it would be simple and easier to just trade for a different tractor with shuttle shift. As far as I know, the 06 JM 254 didn't offer shuttle shift, but I could very well be mistaken.
I guess not having the shuttle shift isn't so bad.
I bought my tractor new (in crate) for $5999. and the shuttle shift was an option then, but I read on here that they had problems with them.
/ Jinma Shuttle Shift #6
Too bad you passed on shuttle shift. In my estimation, the problems I've read about have generally been superficial; usually external and typically and an easy fix.
//greg//
/ Jinma Shuttle Shift #7
I use my creeper gear all the time. I don't think I would want to be without it:)
/ Jinma Shuttle Shift #8
Shuttle Ron, not creeper.
//greg//
/ Jinma Shuttle Shift #9
No, Creeper gear... I do not have shuttle shift. I use creeper(low low) gear nearly every time I use my tractor, particularly when I am working with dirt...
/ Jinma Shuttle Shift #10
You missed my point. This topic is about shuttle shifts, not creeper gears. The mid-connect box can contain either shuttle gears or creeper gears, not both. Shuttle is a lever that takes reverse off the gear shift and lets you go into reverse regardless of what gear you're in.
//greg//
Madvac CS500 Sweeper (A61166)
Madvac CS500...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2013 INTERNATIONAL DURASTAR 4300 (A60736)
2013 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
