Jinma Model 6 Bed Blade
/ Jinma Model 6 Bed Blade #1
VaGlock
Roanoke, Va.
Kubota B2601
I purchased a new bed blade (anvil) for my model 6 Jinma chipper and the new blade has one beveled edge, the original has 2 flat edges. Contacted the seller and he stated to install beveled edge towards the chipper blades. Has anyone run into this before?
/ Jinma Model 6 Bed Blade #2
It is obvious that the new blade you bought is not compatible with JINMA 6'' chipper. As a fixed blade, normally both sides of it are flat and can be replaced and used interchangeably.
I went ahead and installed it as Circle G Tractor Parts instructed me with the tapered side towards the rotating blades, set the gap to specs, They assured me it was the correct bed blade. After running some 2-3 inch branches through the chipper I was not pleased with the way it chipped, turned the blade around with the flat side towards the rotating blades and it chips a lot better. The original bed blade was broken and had to be replaced, so I just figured this was a updated blade. I know now that they sold me the wrong part even though it did fit.
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2020 FORD F-350 (A65643)
2020 FORD F-350...
