Backhoe Jinma Backhoe Suction Strainer
/ Jinma Backhoe Suction Strainer #1
TruChaos
Have any of you installed a suction strainer on the intake side of the Backhoe pump? Debris in the hydraulic fluid seems to really take a toll on the BH controls.
If anyone has done it, how did you attach the strainer? I have a Northern Tool suction strainer but haven't decided how to attach it yet. I've thought about cutting the line and using barb connectors but I don't know the inside diameter of the hose.
I've flushed my tank and it was loaded with paint chips and debris. I haven't hooked my BH up yet and I want to prevent control problems.
/ Jinma Backhoe Suction Strainer #2
What type fitting is the outlet on your tank? A common practice is to use a fine mesh strainer that has a pipe thread fitting. The end of this strainer looks like a pipe adapter fitting. The strainer(1 1/4-1 1/2" NPT) screws into the tank and the outlet line(3/4"NPT) that supplies the pump screws into the strainer. They have these on the Northern tool website.
I don't think the strainer insert will work. The hose is attached to the tank via a banjo fitting with a long hollow bolt through the center.
Thanks anyway.
/ Jinma Backhoe Suction Strainer #4
I use my LW6 with a PTO pump. The suction hose as supplied with the hoe was too small to feed the pump. I welded in a 1 1/2 NPT half coupling and installed a suction strainer as mentioned by RonMar. You might have to change the hose to suit your tractor. I went to a 1" suction hose to feed the PTO pump.
/ Jinma Backhoe Suction Strainer #5
What PTO pump are you using? how many gal per minute? Where did you buy it and how much? Thanks for your help.
/ Jinma Backhoe Suction Strainer #6
I am using a Prince 11 gal/min pump. The rate is much too high so I installed a flow control valve. I used the pump because I had it for a prior project. The LW6 Jinma backhoe needs about 6-7 gal/min. Prince makes a 7 gal/min pump Model HC-7A. These pumps sell for $400-$500 USD new. I originally bought mine from WW Grainger
2016 Toyota Tacoma Pickup Truck (A61568)
2016 Toyota Tacoma...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
2021 Ford Econoline Van, VIN # 1FDWE3FN3MDC22817 (A61165)
2021 Ford...
