Jinma 284LE Overheating
/ Jinma 284LE Overheating #11
Just my opine but the way you just described it sounds like the thermostat is opening late and is defective. Thermostats can fail in so many ways as described above. I'll bet I've replaced hundreds of thermostats in my mechanical career. It is really amazing how a thermostat works.
For those that want to/or care to know how the thermostat works here it is. The thermostat is a thermal bulb with a blend of about 27 paraffin waxes that expand at different rates. It is the mixture of the blend that determines the opening rate of the thermostat. A properly operating thermostat will just begin to open at its designed setting and gradually open to full open at approximately 10 degrees of its beginning setting. Same when cooling down. Generally in an automotive application(which a tractor is) it is always somewhat modulating to the opening. Unless, you are operating under full load or extreme temps then it would always be open, or closed, in severe cold temps and thats why the bypass system is there so coolant can flow when the thermostat is closed. The main reason for the thermostst is to get the engine to "designed" operating temp and help keep it there. That is does pretty well.
Replace the stat and give us the results. /forums/images/graemlins/smile.gif
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Mini Margaritaville Truck (A55853)
Mini...
2008 JACK COUNTY 130 BBL VACUUM  TRAILER (A60736)
2008 JACK COUNTY...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
2016 Terex RL4 Towable Light Tower (A60352)
2016 Terex RL4...
207277 (A52708)
207277 (A52708)
