Jinma 284 Electrical Problems
/ Jinma 284 Electrical Problems #1
don7231
I was having battery problems about 6 months ago. I replaced the original battery which was about a year old. The new battery worked fine for a few months but now it is dead every time I use it. I was able to charge the battery or jump it at first but now I can't even get the tractor to turn over. I used a volt meter and the battery shows 12 volts. I also used the volt meter and connected to two terminals on the alternator and it show 12 volts.
Any ideas what might be happening. Could I have a bad battery? Could it be a bad alternator? Any ideas on what I can check next?
Thanks,
Don
/ Jinma 284 Electrical Problems #2
Unbolt the battery ground cable from the frame and grind the paint down to bare metal for better metal on metal contact.
Also, you should check voltage (at the battery) with tractor running too. After it's started, a good alternator/voltage regulator should make the voltage reading jump to somewhere between 13.2 and 14.5 volts.
//greg//
/ Jinma 284 Electrical Problems #3
if the battery reads 12 volts and the engine will not turn, I would check the starter.
/ Jinma 284 Electrical Problems #4
A bad battery will show 12 volts on a meter, the battery will need to be load tested to get a real reading on the condition of the battery.
/ Jinma 284 Electrical Problems #5
As Greg said, check that ground wire connection where it connects to the frame. I would also check all the connections on the starter itself(with the battery disconnected of course) and both battery connections while you have them off:).
Is this a maintenance free battery or does it have access caps to add water/electrolite to the cells? If it has acces caps, are the cells full of fluid up to the full mark(bottom lip of filler hole)?
The next step I would do is to attach a battery charger and charge the battery overnight(20+ hours) at a low rate 2-5 amps. A fully charged battery should start the beast at least a few times.
With a fully charged battery, measure the voltage at the battery with the engine running. This should be between 13.5 and 14.5 VDC. As an example, my 284 running at 1200 RPM measures 13.9 VDC at the battery. This was with all the lights off. If the voltage regulator is working properly, The voltage should stay fairly constant with load and RPM changes. Under the same conditions, with all the lights(head, running and rear work light) switched on, the voltage only shifted to 13.95 VDC at the battery. Running the RPM up above 1800 had little effect on the above measured voltages.
Good Luck.
/ Jinma 284 Electrical Problems #6
Hi Don,,
Good ideas to check from the other posters. Here's something else to check that I've run into several times. Where the positive cable from the battery connects to the starter post there is a plastic collar that is supposted to center the white wire loop that runs power to everything else on the tractor except the starter. It sits on the post and centering provides good surface contact on the post's hub below. Works fine when it's assembled properly. However when the collar isn't cast quite right and the assembler doesn't trim it plastic flashing can get underneath the white wire's loop and cause intermitant or no power to the dash. That means no power to the solenoid. So the battery will look good but the starter and everything else may not work. Had it happen 6 months ago and again just today on
a tractor in my shop for service. Take a look.
Cheers
Graham
I need some new ideas. I had the battery checked and it is o.k. I disconnected the battery from the starter cylenoid. I connected the possitive lead to the white cable bypassing the starter cylenoid. I jumped from my truck battery to the white cable and ground. My lights and horn work fine. When I try to started the engine, it barely cranks and seems like the battery is dead. I also tried it with the fully charged tractor battery and got the same results. Any ideas? Could it be the starter, alternator, or ignition switch? Thanks for any help, I am about to go crazy.
Don
/ Jinma 284 Electrical Problems #8
Edit, disregard my post. I seen only the post above mine and did not realize this was a problem that has not been resolved. I offered some of the previous advise.
/ Jinma 284 Electrical Problems #9
Don: Reminds me of my own battery problems I had years ago. Battery & connections all checked good but still the battery would go flat if it was left without being started for a few days.
I finally decided to remove the battery from it's metal case & wet it down with a hose and sprinkled baking soda all over the frame. I was really surprised to see it foam up like it did because there wasn't any corrosion on the battery case.
I also wet the entire battery with the hose, and sprinkled baking soda on the top & sides of the battery...again the baking soda & water foamed up. After cleaning both the battery box & battery as described & rinsing with fresh water, my "battery leakage" problems disappeared. I would be careful not to let any of this solution get inside the batttery if at all possible.
I hope your problem is something this simple.
Good luck!
Jon
/ Jinma 284 Electrical Problems #10
</font><font color="blue" class="small">( When I try to started the engine, it barely cranks and seems like the battery is dead. I also tried it with the fully charged tractor battery and got the same results. )</font>
Are you using the compression release? If the engine spins just as slow, you may have a problem other than electrical. And have you checked to make sure the hydraulic quick disconnect fittings just aft of the pump are properly seated? If the hydraulic fluid cannot circulate, pump resistance can cause these symptoms. What color exhaust when it tries to start ?
//greg//
/ Jinma 284 Electrical Problems #11
I'm with Greg on this one. It does sound like a dead-headed hydraulic pump. Could possibly be a gone bad starter, but the hyd system sounds as though it could the the culprit.
/ Jinma 284 Electrical Problems #12
Did you try to jump from the battery starter wire to the starter selenoid (with ignition switch off or trans in neutral) just to see if the starter turned over faster? That would be the ignition switch. /forums/images/graemlins/tongue.gif
Had a similiar problem with my 71 Mustang in which starter selenoid would click when I turned ignition switch to start and the starter itself would just groan. Ended up being the switch. If that doesn't work and all else is right with tractor, a slow starter probably a internal problem with selenoid contacts or brushes/ commutator in starter. You might want to take apart selenoid to see if the contacts are burnt.
camman12
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
UNUSED RAYTREE RMLS18T-18 TON HYD LOG SPLITTER (A60432)
UNUSED RAYTREE...
Rotating Brush Sweeper Tractor Attachment (A59228)
Rotating Brush...
(2) 36"X8' ADS DRAINAGE PIPE (A60432)
(2) 36"X8' ADS...
