Jinma 254 Transmission question
/ Jinma 254 Transmission question #1
Acres1962
I just replaced the transmission fluid in my Jinma 254, with about 1 gallon of "non red" transmission oil. The problem is the unit barely moves in any direction. Can someone tell me exactly how much fluid goes in, and what type? I now read somewhere to use SAE 40 oil?
/ Jinma 254 Transmission question #2
I have a 354, I seem to recall it took about 5 gallons, I used 80W90 gear oil. But folks will have more and stronger opinions on this than religion, so get ready.
Good luck, I'm getting outta here before the OIL-atallahs get here.
/ Jinma 254 Transmission question #3
what do you mean the unit barely moves? this is a gear drive unit not hydrostatic
Scottie
Scottie,
I mean it barely moves forward or reverse even in 1st and in low gear. I do think I may have not used the correct fluid, let alone enough of it. It will move a few feet and stop. It can hardly move up an incline.
Jim
/ Jinma 254 Transmission question #5
The oil will not affect the motion (at least not until a bearing locks up from lack of lubrication. since most the bearing are ball or needle bearings, it would take a long time.
Did the tractor move properly before you changed the oil, or were you changing the oil to try to fix a bad clutch?. Your clutch pedal should have a minimum of 1" of free travel, 1.5 would be better. Is the clutch fully releasing (pedal coming all the way up with free travel)?
gear oil is for the trans, you can use trans/hydraulic (tractor transmission oil). The manual calls for motor oil, but I think that is because they don't have the variety of oils we have in China. MT-5 is yellow metal friently. the only yellow metal is in thrust washers used in the differential, but might as well keep high sulfer out of there.
/ Jinma 254 Transmission question #6
Chip has you pointed in the right direction. You have a bigger problem. As for the gear oil I use 80W90 and it takes about 5 gallons. How much did you drain? Also do you even know it has 4 drain plugs?
Chris
/ Jinma 254 Transmission question #7
I agree. If it were mechanical in the sense a gear selector "between gear" it just would not move...not a little but none at all. Since there is no hydro drive system, the obvious is somehow related to the clutch either being hung up or just not fully engaging. If it worked fine before the fluid change maybe there is something externally that is hanging up the linkage?
/ Jinma 254 Transmission question #8
Well,whatever the non red stuff you put in there[unless it was concrete or something],it shouldn't affect you not being able to move hardly.
Did you put the gears into creeper.
Would say you got the brakes locked,but my neighbors brakes when locked you can't tell,[till you start to smell them that is]
/ Jinma 254 Transmission question #9
How fast are these things in creeper, anyhow - never seen one and I'm curious. Could he be confusing creeper/slow with almost no motion?
/ Jinma 254 Transmission question #10
In low range and creeper? -paint dries faster than the tractor moves a foot:p
/ Jinma 254 Transmission question #11
Yeah,creeper low/low you can keep up with it belly crawling.
/ Jinma 254 Transmission question #12
I believe that the speeds with creeper in Lo and HI/LO shift in Lo are:
.20mph forward in 1st gear and .16mph reverse
RonJ
/ Jinma 254 Transmission question #13
I have never measured it but heard its something like 57' per hour. I use my creeper gears all the time pulling stumps but you use regular gears to get the chain tight then drop it down and pull
Chris
/ Jinma 254 Transmission question #14
When you say the tractor moves a few feet then stops, is that with it in gear and the clutch engaged (pedal fully out)?
If so, I think Chip and Steve are on the right track. Not that I would recommend it, but the tractor should move (while in gear) even if you had nothing in the trans. It's gear driven. I think if it stops while still in gear it's a clutch or linkage related problem.
Rob-
I only saw one, on the bottom of the trans pan. Where are the other 3 located?
/ Jinma 254 Transmission question #16
Why don't you tell us more about this slow moving problem or moving and than stopping moving,or whatever it is,thats what every bodys interested in now.O r did you take it out of creeper and it now works fine?
/ Jinma 254 Transmission question #17
Here is the 'cheat sheet' that I use when servicing mine.
RonJ
It's not in creeper mode. I don't think it is clutch related, as it goes into gears forward and reverse no problems. I would describe it like it slips. It may lurch foward a couple of feet, and then stop. It has a difficult time moving on an incline. This started about two weeks ago, so I looked at the fluid an it appeared dirty, so I changed it. I drained off only about 1 gallon of trans oil through the bottom plug. Is there a hidden screen or filter that I am missing?. The clutch depresses fine, and returns all the way back to the normal position. The PTO works fine, so I would assume that the issue is not with the return on the clutch, but maybe I am missing on this one?
/ Jinma 254 Transmission question #19
Sounds clutch related to me,3rrl is reading this,he's your man!
/ Jinma 254 Transmission question #20
If it's the clutch, Ron at www.ranchhandsupply.com has good info.
That is a two stage clutch, as you're probably aware. It seems clutch related to me as well.
Does it make a difference 2WD/4WD? It seems improbable to me, but either way you've started to isolate the problem.
Good luck.
