Kooosh
Having trouble getting my Jinma 254 to run properly. It will start but won't idle. Have read quite a few threads and it appears my shut-off lever/rod is stuck. I've attached an image of my IP. Pulling on the "pull to stop" does not do anything and there is little movement on the arm which is on the injector pump. More research indicated that I can remove the cover on the back of the IP and free/clean the rod and then add fresh oil. Is the cover that the dipstick goes into the one that needs to be removed?
And when refilling with fresh oil, how do I know how much to put in or should I just check by using the dipstick?
Lastly, that lever on the back of the motor, should it be connected to anything?
Thanks!
Thanks!
