jinma 224 hydraulic filter question
   / jinma 224 hydraulic filter question #1
TSMART
central florida
jinma jm 224
I have printed out the Jinma 100 hour service, which includes lifting out the hydraulic filter. But something is wrong, because on my shuttle shift Jinma, under the seat, there is no suction hose going to this filter. Theres a cover there with three bolts which looks like the right place, but the area under the seat does not look like the photographs used for the 100 hour service. Can someone shed some light on this because I would certainly like to clean that filter. Is it going to be found under the cover with the three bolts on it?
What feeds this pump since there isnt a suction hose like in the photo?? Thanks!! /forums/images/graemlins/confused.gif
It looks similar, but there is NO hose or pipe fitting there, simply the same three sided cover, but it is completely flat. Nothing going in or out there. This is directly under the seat in exactly the same position as the cover you show in your pic. Is that because I have the shuttle shift? (no creeper)...thanks!
   / jinma 224 hydraulic filter question #4
I don't think the shuttle has anything to do with it....but I am not sure??
Must have a different lift box...... maybe someone will chim in that has seen your's before......
Maybe follow the lines coming off the pump??
Ronald
Ranch Hand Supply
it is a brand new 224.
   / jinma 224 hydraulic filter question #6
The hydro filter on my unit looks exactly like those pictures. If you have a newer unit, perhaps posting a few pics here or on the other chinese site can get some input from the dealer community.
   / jinma 224 hydraulic filter question #7
Follow the pipes from the hydraulic pump and tell us where they go,I have several new tractors with shuttle shifts and they still have the hydraulic filter in the original location.?Or e-mail or post some pic's
Tommy
Affordable Tractor Sales
I took a pic , but I think the file is too big to be on the site. Please somebody instant message me so I could email you a pic hoping you could post it for me. I am sure I can email this pic. Just dont know how to reduce it. to the acceptable size...thanks.
   / jinma 224 hydraulic filter question #9
PM me with the pic to me TSMART and I'll help you out by reducing the resolution and post it for you. Not a problem at all. Click on my name to the left of this post and select private message. I too am curious as to what you got there. /forums/images/graemlins/laugh.gif
   / jinma 224 hydraulic filter question #10
Hello, do you know now where the filter is? I have the same problem. There is no suction hose under the seat. I have no shuttle shift at my jinma224 (from 2005/05)
Is that filter perhaps at the suction hose at the right side of the case. But there are 4 bolts on it, not 3 as on several pictures.
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
1997 Cat 953C Crawler Loader (RUNS) (A50774)
1997 Cat 953C...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
2013 Ford F-250 Ext. Cab and Chassis Truck (A50323)
2013 Ford F-250...
