Tires Jinma 224 Ag tire pressure?
   / Jinma 224 Ag tire pressure? #1
dh0765
Hi, I have a Jinma 224 4x4 with ag tires. The rear tires say 250 KPa cold max and the front say 450 Kpa cold max. If I am calculating correctly, this would be approx 36 PSi in rear and 65 PSi in front. Can someone confirm this?
   / Jinma 224 Ag tire pressure? #2
That sounds awfully high to me.
On my Jinma 284, I run the rear at 16PSI and the front at 28PSI.
RonJ
   / Jinma 224 Ag tire pressure? #3
Your conversions are correct...
   / Jinma 224 Ag tire pressure? #4
Yes, your conversions are correct. But I think those figures might be for sealing the beads against the rims or some such thing. And besides, those are maximum figures. Your owners manual should specify recommended tire pressures; which typically convert to 28PSI front and 16PSI rear
//greg//
Greg_g, thanks for your help! I did find it in the manual finally, and it is as you stated.
Thanks,
David
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
