Tires Jinma 224 Ag tire pressure?
   / Jinma 224 Ag tire pressure? #1
dh0765
Hi, I have a Jinma 224 4x4 with ag tires. The rear tires say 250 KPa cold max and the front say 450 Kpa cold max. If I am calculating correctly, this would be approx 36 PSi in rear and 65 PSi in front. Can someone confirm this?
   / Jinma 224 Ag tire pressure? #2
That sounds awfully high to me.
On my Jinma 284, I run the rear at 16PSI and the front at 28PSI.
RonJ
   / Jinma 224 Ag tire pressure? #3
Your conversions are correct...
   / Jinma 224 Ag tire pressure? #4
Yes, your conversions are correct. But I think those figures might be for sealing the beads against the rims or some such thing. And besides, those are maximum figures. Your owners manual should specify recommended tire pressures; which typically convert to 28PSI front and 16PSI rear
//greg//
Greg_g, thanks for your help! I did find it in the manual finally, and it is as you stated.
Thanks,
David
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
1274 (A50490)
1274 (A50490)
