Jinma 204 and 6.5 ft disk
/ Jinma 204 and 6.5 ft disk #1
PartTimeFarm
I'm looking at one of the tractors from Northern Equipment. Right now I'm looking at the 204 (20 hp 4wd) with a front loader. The hardest work I'll have for the tractor is pulling a 6.5 ft tandem gang 3pt disk. I only use it a couple of times in the spring getting a 100 ft x 100 ft garden area worked up after plowing it. The soil has some clay but is not too heavy. Will the 204 have enough power & weight for this? I called Northern and they said it should be fine but I would like to hear from some actual owners. Thanks in advance for any help
/ Jinma 204 and 6.5 ft disk #2
I don't see any significant problem with the harrow. But it begs the question, are you planning to PLOW with the 204 as well?
//greg//
Thanks for the reply. I have another tractor for the plow (1950's JD) so it's not an issue today. But could the 204 pull a single bottom (14 inch) 3pt plow?
/ Jinma 204 and 6.5 ft disk #4
I think the jinma will pull the disc fine. I would have said might be light in front, but the loader takes care of that. 4wd will be nice for the disc.
Your machine, while not a 'plowin' fool' will pull a 1 bottom fine. ( 1-14" ) Heck... Farmall cubs ( 11-14 hp ) pulled 1 bottoms reasonable well... probably 1-12"
You are just shy of having enough HP for a 2-14 or a 2-12.. but you should do fine with 20hp, and 4wd on a 1-14" or middle buster, or subsoiler, etc.
Might not even need a plow depending on soil... disc and box w/ rippers may do it.
100x100 will be easy..
Soundguy
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
Quick Attach Backing Plate (A65579)
Quick Attach...
New Idea 5409 Disc Mower (A66408)
New Idea 5409 Disc...
2022 EZ-GO ELITE...
JOHN DEERE GATOR (A64277)
JOHN DEERE GATOR...
