Jim's new projects
/ Jim's new projects #181
Pretty cool. No limits to our little machines. He's lucky he ended up in front of your house.
I finally got the money together for the wall. I'm not sure about what stackable block to use. I thought I had it picked out and then my honey changed the color on me. Now my selection is a little more limited. Ether way, while we're looking, I'll be trimming out the area in preparation for laying the block. The mini-hoe comes in real handy here along with the big bucket for clearing out excess dirt.
(if it ever stops raining here, I can get started!)
The grass is starting to come in all around the building now.
Thanks, we're getting there. The pace has been slowed by the money for now...
/ Jim's new projects #186
Jim,
That is one very nice project, you can be very proud.
PJ
Highridge said:
Looks Great! :)
Thanks...
I need to level the side where I park the RV. After spreading the stone with my light material bucket, I found that the right side was a little higher than the left. I'll take a pic tomorrow and post it with the motorhome on it. That's the best way to see it. I'm going to take the toothbar off the bucket and spread with that. It seems to go better that way.
I bought a laser level similar to this one..
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92801
I guess I will try again and use that to make sure everything is level.
/ Jim's new projects #190
How you going to do it with the laser level? Just curious, as I never used one before.
Highridge said:
I've got a HILTI laser level like that. It's a really good tool to have and works great too!
I'm thinking that I will spread the stone and place my marker stick on a 2"x4" to get the average level. LTHen just move all over the pad and level ehre necessary. It goes to 100' outside, so I should be in good shape on my 35' x 15' pad.
Setup the laser level on the tripod so that it is perfectly level. Now when I turn it on, it will stripe a level line x inches above the ground. I take a straight stick, (2" x 4") and mark it at the same height as the laser.
Now I move the stick around the pad and observe where the laser is in relation to the mark I made. If it is higher than the mark, I am too low in that area. If it is lower, then I'm too high.
I then just spread the stone with a rake, or the bucket, and keep working it until I can walk around with the marker stick and the laser line is right on the mark, (within reason).
It helps to attach a short 18" flat piece on the bottom of the stick. This will help to eliminate the stick going down into a small depression in the stone.
/ Jim's new projects #193
I've thought about it and thought about attaching a stick to the bucket or box blade and leveling one small area, then marking the stick where the laser hits. That way, I could check level from the tractor seat. I know they have automated equipment that does that for you. I think Blackwell had something like that.
You going to crown it or slope it in any directions?
I will slope very slightly to the back where there is a swale down to the stream bed. I plan to blacktop it when I do my driveway.
Jim!
/ Jim's new projects #195
Most laser levels, except maybe a Hilti, are really pretty useless outdoors unless its dark out. Just not bright enough nor a sharp enough beam to see it well. They have those laser glasses but, well, they're pretty useless too. The manual-leveling one's are easy to get out of whack because people don't always set the level bubbles too well and that will get you several inches off in 25'.
Sometimes old school is the best. We use water levels for our job sites building decks and stuff. Just a 3/8" plastic clear hose filled with water to set the grade. Faster than you can set up the laser, and easily accurate within 1/8" or less for as long of a hose as you like. The water flows to level within the hose ends. Just move one end up and down to your target mark, and the other end follows. Easy and WAY CHEAPER than a laser and does not wear out or go out of calibration. Packs up really quick and you don't have to worry about it being stolen. I could calibrate a laser level using my water level, by the way. Its that good.
Steve
Steve
/ Jim's new projects #196
Steve
Steve[/QUOTI use the clear hose with water in it too to level long distances, I would just like to add I use unsweetened coolaid in the water to make it easier to see the water level and I agree it works.
/ Jim's new projects #197
Jim
Did you use just the rock for your parking area or did you put road base down before the rock.
I am wanting to put a trailer parking area next to my barn and was debating putting just rock. The supplier suggested using 3 inch of road base first and then another 3 inches of rock. What is the preferred method?
Bob
/ Jim's new projects #198
UNLESS YOU HAVE VERY HEAVY TRAFFIC, SUCH AS SEMI'S, 6''-8'' OF CRUSHED STONE SHOULD BE SUFFICIENT. COMPACT BETWEEN 4'' LIFTS.
3'' ROCK WOULD BE A GOOD BASE IF YOUR EXPECTING VERY HEAVY LOADS.
BE SURE AND REMOVE THE TOP SOIL BEFORE SPREADING THE GRAVEL.
FORGOT TO MENTION, IT THE AREA BEING COVERED IS LOW AND GETS A
LOT OF RUNOFF, OR ESPECIALLY SOFT (POOR BASE) THEN IT MAY BE
DESIREABLE TO USE 3'' ROCK.
bbabineau said:
Jim
Bob
I did a larger stone under the 2B stone that provides a little base. I still need to roll it to make sure it will stay flat, but I am waiting until I put the block wall in first.
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
