jimna lubricants
/ jimna lubricants #1
navychief
I have a 284 jimna and i have heard about changing the transmission fluid. the book calls for a 30 weight but could delo diesel 30 weight be a better choice. also the rear end, should it be changed. if so how do you drain it and what weight fluid do you put it it and how?
/ jimna lubricants #2
The chinese specify 30 wt for everything, engien, trans, even hydaulics. Fortunately we have better choices available. Use a good diesel oil (15W40 is my preference) in the engine, use gear oil in th trans/rear (same sump) and front diff. Some people have reported foaming problems so non foaming type of oil is not a bad idea. AW32, R&O or even Universal tractor (303 et al) oil ( any 10-20W hyd oil) can be used in the hydraulic tank under the seat.
535 GAL WATER TANK (A68842)
535 GAL WATER TANK...
2014 Ford E-350 Enclosed Service Van (A66736)
2014 Ford E-350...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
100 GALLON FUEL TANK/ FUEL NOZZLE (A68842)
100 GALLON FUEL...
2011 UNKNOWN FRAC PUMP (A67714)
2011 UNKNOWN FRAC...
