JIC vs. SAE substitution
/ JIC vs. SAE substitution #21
Picker,
you lost me again. Are you looking for a SAE ORB female swivel connected to an SAE ORB male? if so that would be a rare fitting. If you are looking for SAE ORB male to JIC 37 degree female swivel they are plentiful Parker F650X.
As far as brazing fitting fittings. A large portion of tees and elbows used today are all brazed fittings. Just need to socket braze them and not try a butt style braze.
good luck
Roy
This is what I understood from the beginning, ORB swivel??.....the fittings can be TIG welded but that adds more to the costs.....the only female ORB we stock is the ports that get welded to the cyl barrel....Not as a loose fitting...
/ JIC vs. SAE substitution #22
Finally, something I can understand about hydraulics... I'm planning to "plumb" a spool with fittings, my future looks bleek...
It doesn't have to be "Bleek".....just bring what you have to the guys that have good inventory and work it out with them....if no/go then try the next guy....If it's installed on the equipment it's better for the hose/fitting guys to fitup properly.....
/ JIC vs. SAE substitution #23
I bought a bunch of extra fittings and what not's... I have a plan and my fingers cross. If I bring it to someone, I will not learn it... I want to know about hydraulics...
I have to say that I would read these threads over and over and it would not sink in... even after I realized what's going on... I'm still very easily confused.
/ JIC vs. SAE substitution #24
Teg,
It's not hard to figure out hydraulics in general once you understand it.....as far as plumbing issues some guys that work on hyd equipment cannot plumb worth a darn, they don't have a eye for it...Yea it'll work, but looks goofy.....doesn't mean they are no good at hydraulics, just the plumbing task.....Plumbing components in tight quarters always is a challenge.....the closer the conections=the harder it is to fit up.....
Also the more adapters you use means more potential for leaks....:mad:
I guess it's like anything you do (hydraulics, woodworking, welding,electrical, machining....ect) you should be able to envision your project before you start.....This potentially eliminates trouble from the get go.....
Remember: the 7 P's Rule
Prior Particular Planning Prevents Pi$$ Poor Performance....:thumbsup:
/ JIC vs. SAE substitution #25
Picker, did you get a different cylinder than what you started out with? I thought that you had a 1 1/2" dia cylinder? :confused3:
In case I decide I can't live with the approx 1" per hour leak-down on my new side link. I think it will be ok for box blading because I'm usually floating the box blade anyway, don't know yet if I'll want to put up with it when the brush hog is on there. Fortunately, the brush hog isn't used much since I got a big ZTR, I much prefer mowing with that.
I'm not sure why this is happening, but it is. SCV's are brand new and hard piped by the dealer, and shouldn't be leaking down like that IMO. Could be the new cylinder, I suppose. I used a 1.5"x6" for the HSL, and a 2"x11" for the HTL. Of course the top link has a DPOCV so it stays exactly where I put it.
It's a personal thing, I guess. I just hate droopy hydraulics. I thought it might be sucking air somewhere, but it's dry as a bone under pressure, and we're only talking a set of QC's, two 36" hoses, and a cylinder in the entire loop. Any kind of leak should be obvious.
P.S. Don't say it, MVR. I already know your opinion of DPOCV on side links. :laughing:
Oops. I mislabeled the cylinder, it IS a 1.5.
Picker77, did you see this post? would any of their arrangements help your setup?
http://www.tractorbynet.com/forums/hydraulics/185755-position-hydraulic-hoses-top-link.html
Yeah, Spud, I remember seeing that but didn't have it bookmarked. Thanks. If nothing else works out I can use something like that for a fallback position, but this DPOCV is a lot smaller than that one (although not quite as small as the ones used by CCM), so I was hoping to squeeeeeeze this puppy in there somehow if I can, using only connectors and no tubing. From the git go I was shooting for a clean and compact install. Still don't know if I'll get there or not.
I probably could also use this 6" stroke 1.5" cyl for something else and get a different cylinder with a longer body, which would make a much easier fit-up--but I had this one on hand so I'm being stubborn. Besides, I already butchered the rod on this one by putting a nice custom-fitted clevis on it, so I'd have to come up with a new use for it.
Funny thing is, this side link cylinder works great just like it is, I just didn't like the way it leaked down after sitting still a while, which is what sent me off down this yellow brick DPOCV road. Maybe the grass isn't greener over there after all, and Murphy is teaching me another little lesson. :laughing:
/ JIC vs. SAE substitution #29
Small, compact, hard to get much cleaner than this.;) And you know that if you had gone with a 2" cylinder, your leak down would have been even less noticeable.:mur:
Just giving you a hard time. :laughing: :D
/ JIC vs. SAE substitution #31
SAE Straight Thread (O-Ring Boss) female swivels are not just rare. I don't think they exist at all. I sell fittings for a living, and I have never seen an SAE female swivel. All SAE/ORB female fittings are solid.
A female swivel fitting needs some kind of an internal seal, and SAE/ORB fittings don't have one. The seal on ORB is external, with no way to prevent a swivel nut from leaking at the point of the swivel.
/ JIC vs. SAE substitution #32
My sentiments exactly....I also sell this stuff everyday and have never seen or needed one of these.....3 other ways of hookup I've suggested.....:)
Ok, you guys... pass the stick around and let others have a chance. :laughing: :laughing:
Memo to Wdchyd and MtnViewRanch:
Fedex is supposed to deliver the JIC-SAE straight swivels tomorrow. If I can't make this work, I like my crow medium rare with salt and pepper and a tad of Louisiana Hot Sauce. :laughing:
/ JIC vs. SAE substitution #35
Now I'm really confused, :confused3: I never said anything about the swivels. I hope that they come in and all your problems are solved. Are you maybe thinking about wdchyd and Hydraulic Hose Guy? :confused: The only thing that would have been better would have been if you had purchased your hydraulic side link from me. ;)
/ JIC vs. SAE substitution #36
MVR,
You're not confused.....Ooops.....I didn't have the stick......:ashamed:
You can't get in trouble on here, we have too much fun. MVR was right, I should have said Hydraulic Hose Guy. Don't give up on me yet, MVR. Before this is over I might buy one yet, LOL!
Too bad all forums don't have the same level of intelligence, expertise, and sense of humor among members that TBN has.
/ JIC vs. SAE substitution #39
You ordered a fitting with an SAE/ORB Female Swivel? Where did you find this?
/ JIC vs. SAE substitution #40
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
