Jerky hydraulics on L3400HST
   / Jerky hydraulics on L3400HST #1
aimcorep
Cle Elum, WA
L3400HST
My L3400HST has shown some jerkyness in the steering and bucket hydraulics since the last service I performed. It has around 850 hours and this was the third full hydraulics change I have done. It was fine until I did this service, any ideas?
Most of the symptoms go away after a full warm up providing I keep RPM above 1800...
   / Jerky hydraulics on L3400HST #2
Probably just air getting into the system. Check the fluid after initial startup by letting it run for a few minutes and pull the hyd. dipstick. Look for foamy or milky oil. Try tightening your new hydraulic filter a bit more, and also any hose clamps on the suction tube leading to the hyd. pump. Can't hurt
Thanks for the tip, I see some seepage at the hyd return line. I'll start there, replace the hose and see what happens.
Thanks again for the info...
Brad
The tractor is a 2006 with 850 to 900 hrs. Everything else seems to still be working fine.
Let me start by saying Thanks Teg! The hose was the problem and the new hose fixed all of the problems. You saved me lots of diagnosis and no doubt money.
The hose had moisture but not enough to make me think it was any more than a loose clamp. I was ready to order the hose but thought I would put a hose clamp on the rear end just to see if it would help. I had been suffering some jerky hydraulics and steering until that point and come to think of it, it had been slowly getting that way for probably more than a year or two. Starting with the hydraulics seeming to slow down, more and more.
When I installed the extra clamp things went bad fast. I had apparently pinched the area that was leaking. It went from jerky to almost non-existent hydraulics and from jerky steering to no power steering, not fun. At least I then knew I had pinpointed the problem.
I bought the Kubota part locally (about 25% more than Messicks including delivery) because I wanted it now.
Replaced the hose in about 5 minutes with little loss of UDT and it was fixed! After removal it was easy to see the split near the original clamp at the 90.
Thought I would have to work to get it bled but I started the tractor while I was cleaning up and when I sat in the seat a couple minutes later, it was perfect. The hydraulics were back to new condition and the steering was flawless.
Thanks again for the tip!!
Brad Wiechelman
   / Jerky hydraulics on L3400HST #9
You're Welcome... :thumbsup: Duck tape worked for me for a while :p until I got my new hose. The replacement should last a lot longer...
   / Jerky hydraulics on L3400HST #10
Ha, I thought that was the whole reason.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2009 Champion C80 B Motor Grader (A50322)
2009 Champion C80...
2016 Ford Fusion S Sedan (A50324)
2016 Ford Fusion S...
Gleaner R50 Combine (A50514)
Gleaner R50...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
