Jerky hydraulics on JD 5310
   / Jerky hydraulics on JD 5310 #11
Might be a good time to get a copy of the tech manual for the 5310. Dealer or a place like ebay. That will be a big help for your friend as well as yourself.
Yes, early on a kind member of this forum actually pm'ed me and sent me the doc in PDF format. I couldn't believe his kindness. :thumbsup:
   / Jerky hydraulics on JD 5310 #13
I would sure like a copy of the tech manual in PDF form for my 5310. I have not been able to find it anywhere.
   / Jerky hydraulics on JD 5310 #14
I took out the relief valve and it looks fine. Put it back and no change.
At this point, the only thing I can think of is that I have an air leak somewhere, perhaps one of my hoses is bad. I have a friend in town with a hydraulics shop and I'll be taking my tractor to him as soon as I get my trailer fixed.
The suction hose would be the one to really look at because the others would be leaking oil...
   / Jerky hydraulics on JD 5310 #16
Hose is #14. Orings #19 and #21 could also leak air into the suction line.
Thank you sir. I'll have a look see tomorrow.
   / Jerky hydraulics on JD 5310 #18
Hey DRW, what'd you find out on this? Having the same issue.
I actually never got it fixed and the tractor is sitting, waiting for me to get back to it. Interestingly, my little Kubota tractor started exhibiting the same behavior and I quickly found that there was a crack in one of the non-pressurized hoses that is under the clutch. It was sucking air into the hose.
I am certain the problem here is that air is getting sucked in to the system somehow. One day I will clean all the hoses off and make the tractor clean, then start it and run the hydraulics. Any cracks or leaks will hopefully show oil dripping and then I'll know where my leak is.
   / Jerky hydraulics on JD 5310 #20
It sounds like the suction line is usually suspect on these... I will dig into it further and let you know how things go on my side... probably not going to happen for a week or so... Thanks your response!
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2007 INTERNATIONAL 9200I (A58214)
2007 INTERNATIONAL...
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
2021 Kubota SVL75-2 Track Loader (A56435)
2021 Kubota...
Heavy Duty Solid Steel Skid Steer Mounting Plate (New/Unused) (A59225)
Heavy Duty Solid...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
