Jerky cutting board
/ Jerky cutting board #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I made this board for slicing venison for jerky. One side is 1/4" and the other 3/8" thick cut. It actually finds more use than I would ever imagine, the wife best of all uses it for filleting fish and slicing chicken breast and such.
/ Jerky cutting board #2
Nice looking board.
I used to cut jerky with a knife back when I still tried to make steaks and roasts out of venison. Now I either have sausage made, or cut it into jerky. The knife is too slow, so I bought a meat slicer and open it up the the thickness that I want. Then I run it through the slicer and get some thin looking steaks. I then cut those into strips for jerky with my sheetrock knife. I can change it out to a razor sharp blade in seconds.
Eddie
Thank you. Maple finished with olive oil - my favored combination.
What type/brand of meat slicer do you use?
/ Jerky cutting board #4
Prokop, Add some knives and you have a nice Kraut cutter. Multi purpose Board!:D
/ Jerky cutting board #5
I don't know the brand, it's been a few years since I used it and it's buried in my storage area. I will tell you that I made sure to get stainless steel cutting wheels and tray. The motor is pretty basic, but the stand is very heavy. When you put it on the counter, it stays there. Mine is almost 20 years old.
Friends bought cheaper models, but they didn't have the power to handle bigger pieces of meat or the metal started to rust on them. If I was to buy another, I'd look at commercial for sure. I do believe you get what you pay for in something like this.
I would spend hours cutting jerky before buying this. After buying it, I was done with cutting and cleanup in an hour.
Eddie
/ Jerky cutting board #6
Wow, Prokop, thanks!
I've been making jerky for years and never heard of such a cutting board. At first I couldn't figure out how it worked, but Google was my friend.
My approach has always been to just take a really sharp knife and approximate a 3/8" cut. It was quick, but the sizes are never uniform.
I'm going to have to go out and make one of these!
I'm assuming an electric knife would make the process much quicker?
/ Jerky cutting board #7
Had to read this when I saw the title. There's been complaints about the TPH on some of the "economy" model Kubota lifts that are jerky, but I couldn't imagine living with a jerky cutting board, neat idea.
I use sharp filleting knife, since it is narrow and the resistance is low. It flexes in the middle of the cut, but I can live with that. Electrical knife could orobably work faster, but I like sharp knifes and I am somewhat proud of my cutting and slicing abilities - just one of my little perks:D
/ Jerky cutting board #9
Yeah, I really enjoy using a really sharp knife as well. I've got the Jet sharpening system (Tormek look-alike) and have easily invested over $1,000 just in sharpening systems. (I also do woodworking). Needless to say, I try to keep all of my tools razor sharp.
But, I just received a new Rapala electric fillet knife for my birthday, and I'm looking for excuses to use it. :)
/ Jerky cutting board #10
Using a knife, the meat is easier to cut if it is a little bit frozen.
/ Jerky cutting board #11
I've noticed that as well -- it doesn't move around on you when it's frozen, and if the knife is just a little bit dull, you need the meat to stay put so you can "saw" your way through it.
Also, it is much easier to cut in a straight line when the meat is frozen.
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
Patterson water pump (A59230)
Patterson water...
