3-Point Hitch Jeff
   / Jeff #1
Jeffreylee
Grafton
Tc55d
I am having trouble with my pto clutch. I was tilling with my TC55DA when my pto shafts quit spinning. I raised it up it started spinning again. So I put it down. Went a little futher and it stopped spinning again. Is the something wrong with my pto clutch?
   / Jeff #3
Was the PTO shaft from the tractor spinning, but the tiller was not? It can look like the tractor PTO is not spinning because the shield is not. Do you have a slip clutch on the tiller? More than likely, the shaft is spinning inside the shield, and the slip clutch on the tiller is slipping. Readjust that per instructions.
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Forklift (A59228)
Forklift (A59228)
9ft 4in Flat Bed (A57453)
9ft 4in Flat Bed...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
207281 (A52708)
207281 (A52708)
