JDQA dimensions?
   / JDQA dimensions? #1
larboc
hancock, MI
John Deere 4300, Deere 455, Ariens GT17, Cub Cadet O, Wheelhorse 50
Anyone have the drawings for the JDQA system? Namely center-center hook distance. I measure it being approximate 40.25" but it would nice to know for sure instead of being at one extreme of clearance.
   / JDQA dimensions? #2
That sounds about right.
I just went out and measured my 300CX, I went between the outside edges of the hooks of the implement attached, and that was 43 1/4".
The hooks were 3" wide... so that would make it 40 1/8".
I did measure twice to be sure. :)
   / JDQA dimensions? #3
Here is a drawing of mine I measured years ago thinking I would make some attachments, but never did. The hooks and pins you can but from JD dealers so you don't have to make those if you want.
   / JDQA dimensions?
Seems like the kind of thing that deere would have 1) Made all dimensions exactly to the nearest half inch and 2) Published. Thanks mama deere.
Thanks for the prints, I ended up making multiple trips through the snow from the shop to the barn with a tape measure and go it figured out.
I'm a little skeptical of your width, that puts the center to center distance at 40.05" which I think is too narrow. The 15" dimension is a little shorter than I remember and I was using deere weld on brackets. I had 15 1/16th from the top to the center of the pin.
   / JDQA dimensions? #5
larboc
What is in the barn that you are measuring? suspecting it is a 420 or 430 FEL. or is it something else?
   / JDQA dimensions?
   / JDQA dimensions? #7
View attachment 533667View attachment 533668I don't recall how I measured them many years ago. But I just checked my widths today, and it is just under the 43.5" for the overall. I suspect I measured it with the bucket off the first time, and probably picked up the widest points. Bucket is on now, and didn't take it off. This is on a 300CX with light duty bucket. My overall is just a hair under 43.5" from outside to outside, but might be a bit different with the bucket off and measuring from a more solid spot on the brackets. That puts the inside dimension at about 36.5", and center to center at around 40".
See pictures for measurements.
   / JDQA dimensions? #8
Prolly is really in metric, so center to center maybe 102 cm.
But as long as you have the FEL that you want to fit up to, then actual measurements of the FEL should work for your attachments.
What attachments are you fabricating ??
   / JDQA dimensions?
Interesting. 40" even would make sense to me but there doesn't seem to be 1/4" worth of play. When I find my original bucket (under 100" of snow now, somewhere in "implement row") I'll get some precise measurements and see what I have.
   / JDQA dimensions?
Made pallet forks, adapted a 7.5 box blade, working on making a post hole digger.
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2010 CHEVROLET SILVERADO 1500 (A53843)
2010 CHEVROLET...
Tafe 45DI (A50123)
Tafe 45DI (A50123)
2021 Polaris RZR 1000-4 (A52384)
2021 Polaris RZR...
2025 JMR 40in Single Cylinder Grapple Mini Skid Steer Attachment (A51691)
2025 JMR 40in...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
