JDQA dimensions?
   / JDQA dimensions?
I'm currently building a JDQA quick hitch. I expect to use it with my 3 point trailer mover so I can put trailers away driving forward instead of backward and also with a boom pole to get higher lifts. It may be handy to move 3 point implements around while something else is on the back. Maybe not the greatest tool ever but it's a pretty easy project.
I just put a 2" receiver on the back of my forklift frame to move small trailers. Built a 3-point one a while back for heavier ones and my gooseneck.
   / JDQA dimensions?
Sounds interesting, but I wonder if there is enough flow for that. I think there is only like 8GPM on these tractors. Used post hole diggers are pretty cheap (at least around here). You could always extend the frame on a PTO digger to get more throw out of it and make an extension for the auger. I think you will get a lot more torque and speed out of a PTO digger. I used mine several times, and the key is just good teeth on the auger, and I have a lot of clay. But, I would like to see a hydraulic post hole digger on it.
I really don't like the 3Pt system on my 4x10 tractors. I have the lift arms as short as they both go, and still it seems like I don't get much height out of the 3 pt.
8gpm should be enough. Commercial skid-steer mount post hole diggers in the size I'm looking for are rated for that. One example I found specs 5-10 gpm and up to a 14" auger which would be big enough for me. They are just really expensive for what they are and none are JDQA.
2013 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A52707)
2013 CATERPILLAR...
Killbros 375 PT Gravity Flow Wagon (A56469)
Killbros 375 PT...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
1992 Pine 53ft. T/A Dry Van Trailer (A55852)
1992 Pine 53ft...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
2006 iDrive...
UNUSED SDLANCH PORTABLE WOOD CHIPPER (A57193)
UNUSED SDLANCH...
