Price Check JD950 price check
/ JD950 price check #1
sands
Texas
JD 950/ 1988
JD950 1988 with 75 FEL 6'box blade. has 40 hours on rebuilt motor, trans and hydrolics. $9,450
/ JD950 price check #2
You don't say whether it has MFWD or not. I bought a 1984 JD 950 about 3 years ago. It has MFWD, PS, 75 loader, and about 2000 hours. Good condition. I paid $8650 for it. Nice tractor for the price.
/ JD950 price check
BB_TX Thanks for quick responce. I was looking at getting a NH33D but came across the 950. How do you like your 950? Do you have any specs for the 950 tracktors? I think it is 2wd with PS.
/ JD950 price check #4
This Thread has some specs for the 950. I can provide a copy of detailed specs if you need them.
/ JD950 price check #5
<font color="blue"> tractortips.com </font> and <font color="blue"> tractordata.com </font> both give basic specs on lots of tractors, including the 950.
I am quite happy with mine. Does everything I need. I think the MFWD (4x4) adds a lot to it's ability.
I run a 6' light duty rotary cutter behind it for pasture mowing and light brush clearing. That is right at the high end of what it can run. Works fine unless the grass is high and really green and heavy. Then I just slow down a little.
/ JD950 price check
Thanks for the specs on the tractor. Do you know of any for the 3 point and 75 loader? I will post pic when I get some but from what I have been told this is very clean tractor.
Thanks.
/ JD950 price check #7
Don't have any info on the 3pt or loader. I assume you are interested in lift ability? I have an operators manual but it is with my tractor about 30 miles away. I don't remember it giving any 3pt lift rating though.
If you are mechanically inclined and intend to maintain your tractor yourself, I would recommend you get an operators manual, parts manual, and shop manual. The 3 manuals will run a little over $100 if I remember correctly, but will save you that and more if you have to do any repairs. You can get those at your JD dealer or by calling an 800 number and having it mailed to you, which is what I did. Unfortunately I can't find that number. I am sure someone will jump in here with it though.
/ JD950 price check #8
My owners manual did not specify 3pt capacity or hydraulic flow. The original product brochure does not have this info either. There is capacity info on the loader. I can look that up when I get home.
/ JD950 price check
Thanks for all the replys. Jerry that loder info would be great.
/ JD950 price check #10
Oops, forgot. /forums/images/graemlins/blush.gif I'll make a note to self for tonight.
/ JD950 price check #11
Loader lift is 900lbs. to full height. 3ph is a hair over 1,000lb.
Hydraulic flow is either 9-10 gpm. 50 series rigs are not real fast, but they are tough little boogers. The 1050 has put up with my use/abuse since '87 without any major hiccups.
/ JD950 price check #12
My product brochure says 950 lb capacity for the 75 loader. No specs are given for the 3pt hitch.
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
159116 (A60430)
159116 (A60430)
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
