JD950 Cam Shaft Removal
   / JD950 Cam Shaft Removal #1
David_fogfive
John Deere 950
Hello All,
I have a JD950 with 3T90J Yamnar engine.
I’m currently doing an overhaul on the engine and having issues removing the cam shaft from the block.
The tech manual doesn’t really help on this, and can’t find any videos or online information.
I’ve removed the governed nut and governor and the Phillips screw with the bearing retainer.
I’m assuming the bearing is pressed into the block?
Any advise or tips would be greatly appreciated!
   / JD950 Cam Shaft Removal #2
Welcome to TBN
Wish I could be of some help.
   / JD950 Cam Shaft Removal #3
Hello All,
I have done 4 similar Yanmar engines from other Deere tractors. Camshaft removal was pretty straight forward. The plain bearings (sleeve bearings) were pressed in.
For JD, you often have to get a separate manual for the engine. Or aftermarket, like I & T.
Can you post some pix?
Here’s a few pics…
   / JD950 Cam Shaft Removal #5
The tech manual shows that that bearing is pressed onto the cam.The cam should just pull out if you have the lifters (followers) out of the way.
I ended up getting it out. Had to put a pulley puller on the cam gear and reverse knock it out.
   / JD950 Cam Shaft Removal #7
I was just going to reply saying to use a pulley puller as this is the way us with Yanmars often do it.
If you are into this deep of work on a Yanmar made machine, often the Deere owners come over to our Yanmar section for help or the YTOG.
Additionally, Deere has discontinued many parts for the 50 series. On the YTOG, we have the parts suppliers with the Yanmar OE parts that are the same for the Deere machines.
Dry good to know. Thank you for the info!
BESTWAY AG VSK50 LOT NUMBER 104 (A53084)
BESTWAY AG VSK50...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
