JD790 Battery/Alternator Problem
   / JD790 Battery/Alternator Problem #11
Having a wiring diagram is very helpful. Ok, it's an alternator with external electronics (rectifiers and regulator). That means that the external leads from the alternator are AC, and current carrying. With this setup, the leads leaving the alternator and any connections in the leads are many times themselves the issue, but if not, any problems with the charging circuit are almost always the regulator (which is actually the rectifier and regulator). With the leads disconnected, they will measure up to 50 volts depending on the speed that the alternator is turned.
So check for broken/intermittent wires, overheated plugs, and that sort of thing. If you don't turn up an issue with the wiring, my bet is on the regulator.
Hope that helps,
Tom
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
CAT 336E (A58214)
CAT 336E (A58214)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
TANK MANIFOLD (A55745)
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
1996 Transbridge Detach Low Boy (A59814)
1996 Transbridge...
