JD755 transmission.
/ JD755 transmission. #1
SteveHx
JD755
I have a JD755 tractor. Just changed head gasket in attempt to resolve overheating. While test running in garage noticed transmissions fluid dripping. Found dip stick at back of tractor. It’s low on fluid. I cannot find where to add fluid. There’s nothing at the back. Any ideas?
Thanks
/ JD755 transmission. #2
Do you have the TM1360 manual? It will tell you everything you need to know about the machine. Even to know it was made 100% by Yanmar. :)
I got the manual if you want it for FREE in PDF.
/ JD755 transmission. #3
I have a 755. It should be at the rear of the tractor near the dip stick, kind of near the top there is a screw cap. Let me know if you still can't find it and I will send pics
(2) UNUSED 23X8.50-16 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
Service Truck Body (A61573)
Service Truck Body...
Kubota L2501 (A62177)
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
