JD5403 turn signals , flasher, brake light quit
   / JD5403 turn signals , flasher, brake light quit #11
But the light switch would not control brake lights not working. Sounds like possible ground wire issue to me. Most of the light bulbs are controlled by 2 or more wires running to each lamp. The grounds are run back to a centralized grounding block. If you lose ground to this none would work. Ive seen this in trailers and older cars. When I reestablish a temporary ground on one light, the rest start working. Worth a try
Sorry, our tractors don't even have brake lights. But usually brake lights run through the turn signal system. Turn signals are usually the brighter element in a 2 element bulb (same element as brake lights).
Our tractor was having lighting issues, and I took apart the main rotary switch and cleaned it and it worked.
Our tractors have a rotary dial to turn on lights, but maybe you should check the turn signal switch closer.
I will try to check that tomorrow. Thanks.
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
9000 (A47477)
9000 (A47477)
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
