JD5403 turn signals , flasher, brake light quit
   / JD5403 turn signals , flasher, brake light quit #11
But the light switch would not control brake lights not working. Sounds like possible ground wire issue to me. Most of the light bulbs are controlled by 2 or more wires running to each lamp. The grounds are run back to a centralized grounding block. If you lose ground to this none would work. Ive seen this in trailers and older cars. When I reestablish a temporary ground on one light, the rest start working. Worth a try
Sorry, our tractors don't even have brake lights. But usually brake lights run through the turn signal system. Turn signals are usually the brighter element in a 2 element bulb (same element as brake lights).
Our tractor was having lighting issues, and I took apart the main rotary switch and cleaned it and it worked.
Our tractors have a rotary dial to turn on lights, but maybe you should check the turn signal switch closer.
I will try to check that tomorrow. Thanks.
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
ATTENTION! PLEASE READ (A56469)
ATTENTION! PLEASE...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
(APPROX.48) UNUSED 2X4X10 PREMIUM GRADE LUMBER (A57192)
(APPROX.48) UNUSED...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
