JD500b starting problems.
   / JD500b starting problems. #1
PaulJD500b
JD 500b backhoe
I have a JD500b diesel backhoe. It has starting issues and I am losing my mind. Problem came on all of a sudden. It just clicked at first, wouldn't even start with a jump.I replaced the starter relay on the firewall. It still just clicked, but then none of the dash lights would come on and there was intermittent power to the ignition switch, but the machine would start with a jump. Now it won't start at all. Tested the batteries and they would drop to 6v when the key was turned, so replaced the batteries. Then when I tried to connect the new batteries the starter kicked when I attached the positive cable. Figured solenoid or starter, replaced the solenoid, no change. Thought maybe ignition switch, took it out, no change. What is going on?
   / JD500b starting problems. #2
Welcome to this forum.
Are you positive that you have battery cables are attached correctly?
I suggest to clean/tighten battery negative cable where it attaches to tractor frame.
Check battery cables under insulation for corrosion.
If batteries voltage won't go over 12 volts then I'll suggest to have new batteries load tested
Auger Skid Steer Attachment with Bits (A59228)
Auger Skid Steer...
Chariot 12' Box Trailer (A59814)
Chariot 12' Box...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
Mini John Deere Truck (A55853)
Mini John Deere...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
Butler MFG Water Tanker (A56438)
Butler MFG Water...
