JD4600 engine 4tne-84
/ JD4600 engine 4tne-84 #1
buckleupbilly
JD4600
I have a JD4600. was runnning good after getting started with parts and brake cleaner. Had Head resurfaced and valves ground. Insalled with new gasket and fuel injectors, cannot get it to start. pulled head again, new gasket, same problem any help on this appreciated.. thank
/ JD4600 engine 4tne-84 #2
You were starting it with parts cleaner and brake cleaner????
Are the injectors bleeding fuel?
not sure what u mean. fuel getting to injectors, leeking when loosen nuts
fuel leaking when nuts are loose and trying to start
yes, only way it would start is 1 shot of parts and brake cleaner into intake would start immediately , ran great after that, thanks
/ JD4600 engine 4tne-84 #6
It didn’t run great or you wouldn’t be here. You pulled the head again and said “same problem”. Blown head gasket again?
/ JD4600 engine 4tne-84 #8
you're not getting fuel. have you checked you fuel stop solenoid? have you used the lift pump to prime the injection pump? it can take some time to get these primed. if it runs with other fuel sources ( aka break cleaner ) then your not getting fuel.
/ JD4600 engine 4tne-84 #10
Whatcha NEED TO DO is take an injector out of the head and hook the line back to it.. now crank the engine and SEE if it’s opening the injector.
/ JD4600 engine 4tne-84 #11
Do you have electronic fuel control? If so check the electronics are working properly. I once ran into a no fire condition on a JD6910 and it mimiced no fuel perfectly ,fooling the mechanic. The real problem was the electronic fuel control had a partial failure and was not lettting fuel through even though fuel was primed and at the injectors. NZ$9200 was spent overhauling the fuel injection pump. A waste of time, and we still had to buy a replacement ecu. grrrrrr
/ JD4600 engine 4tne-84 #12
is your fuel stop a 2 wire or 3 wire unit ?
/ JD4600 engine 4tne-84 #14
check ur fuel stop valve 1st .
/ JD4600 engine 4tne-84 #15
If u have fuel up to the pump inlet AND your solenoid is working properly..
Yes, time to pull the pump.
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
TR 23 Trancher (A64127)
TR 23 Trancher...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
