JD450C Crawler Dozer
/ JD450C Crawler Dozer #1
lsts
Eden, GA
JD 450c
I recently purchased a used JD 450C Dozer. Unfortunately someone has destroyed the wiring system on it. The only wire that I can't figure out is the one coming from the back of the alternator from the voltage regulator. It is in the wire bundle that goes from the alternator hot to starter and ends almost at the starter, and has unfortunately been cut. I have a maintenance manual for the dozer but it doesn't show where this particular wire goes. Is there anyone that can help me with this?
/ JD450C Crawler Dozer #4
someone may have put an alternator on that has built in volt regulator and that may be why wire is cut that comes from volt regulator
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
2014 International DuraStar 4300 S/A Dump Truck (A61573)
2014 International...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
