JD450C Crawler Dozer
/ JD450C Crawler Dozer #1
lsts
Eden, GA
JD 450c
I recently purchased a used JD 450C Dozer. Unfortunately someone has destroyed the wiring system on it. The only wire that I can't figure out is the one coming from the back of the alternator from the voltage regulator. It is in the wire bundle that goes from the alternator hot to starter and ends almost at the starter, and has unfortunately been cut. I have a maintenance manual for the dozer but it doesn't show where this particular wire goes. Is there anyone that can help me with this?
/ JD450C Crawler Dozer #4
someone may have put an alternator on that has built in volt regulator and that may be why wire is cut that comes from volt regulator
PackRat Tool Box & 100 Gal Tote (A64119)
PackRat Tool Box &...
2017 Ford F-350 Flatbed Dump Truck (A61573)
2017 Ford F-350...
2019 Ford F-150XL (A64119)
2019 Ford F-150XL...
Kubota ZG222 (A60462)
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2017 Gehl RS6-34 (A64119)
2017 Gehl RS6-34...
