JD4500 Not going into C Range
/ JD4500 Not going into C Range #1
MMH
Murrysville, PA
JD 4500
I have a JD 4500 w/ MFWD and a PoweReverser transmission. I cannot get it into the C range. Also, when I move between A, B, neutral and C it feels 'gritty', and there are no distinct stops between any of the ranges. I could live w/o the 'C' range but am worried that I will lose the other ranges.
The tractor is about 20 years old, is stored outside and has 2500 hours of fairly heavy use. Allot of digging w/ FEL & backhoe along w/ a bunch of grading. Anybody have any clues as to what may be going on?
/ JD4500 Not going into C Range #2
...but it still shifts from A to B OK?
The 4500 is a slightly bigger series, but the 4200/4300/4400 all had weak range shifter shafts, and were prone to breaking off. No detent feel is a bad sign.
It does still shift from A to B but the feel is very vague (do not feel any of the detents). When I try to engage C it seems as if only half a shift occurs and I hear gears grinding. Your assessment of a shift shaft issue seems logical.
How difficult is it to replace the shift shaft? I presume that nothing crazy needs to be done (like splitting the tractor).
/ JD4500 Not going into C Range #4
On the 4300s I had, it can all be done from the top, after removing the 3-pt cylinder cover. There are several write-ups on TBN, including mine. One guy even had a new shift shaft made that did not have the weakness. Do a search.
429835 (A61166)
429835 (A61166)
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
