JD447 Baler?
   / JD447 Baler? #11
I just reread your post and saw 15 acres to hay. Not sure on what your ground yields now for hay, but that could be baled in a few hours easy with 4x4 baler, no ramps and twine. I would assume you'd break it up though.
I see 2850M listed for tractor, that will just be on the low end of size and power for a 4x4 baler, still go 3-4 MPH with it.
   / JD447 Baler?
Yeah I realize I'm a bit light on HP but the budget is what it is (was!) I may go up to 20 acres here, I need the rest for other stuff plus 30 are wooded but I'd like to find some land locally to rent/lease to hay .... one day! Thanks for the info.
   / JD447 Baler?
Looks like I’ve missed this baler. Salesman is still in negotiations with a customer wanting to trade. I got the impression the salesman would have welcomed a straight sale with me but is rightfully honouring the trade deal.
There’s a very tidy New Holland BR7050 (4x5) over by the mountains which I believe I can just roll 4x4s on? But it states min HP 50 and my pto HP is around 40. If I was just doing 4x4s, would I get away with being so underpowered? I don’t want to tear my new tractor up but can I just drive slower and only roll to 4’??
   / JD447 Baler? #14
If on flat ground only, I think it’s possible.
Too bad we aren’t “in season” so you could take it from dealer and try it for a day.
I’d be looking for an old reliable 2WD tractor with about 75-80HP to pull it. Who cares what it looks like, just something to attach the baler to. You can get a tractor like that for 5-10 grand.
   / JD447 Baler? #15
I wonder if the recommendations for hp are more for safety/brakes and weight so the tail doesn't wag the puppy. I've seen people use smaller than recommended tractors. Usually within a year or so they get replaced with something larger.
   / JD447 Baler?
That had crossed my mind too, especially after seeing a YouTube guy ( tractor time with Tim?) using a round baler behind a sub compact!
   / JD447 Baler? #17
I baled (with a small NH square baler) about 2 miles of wheat straw swath with my 4410 for the fun of it. The tail wagged the puppy and I don't think the pto would handle the intermittent strain long term. But it was fun and the cruise control/hydrostatic transmission worked awesome to keep the baler at capacity.
   / JD447 Baler? #18
BR7050 is 4x4 baler and part of the 630/634/638 lineage. When the 630 came out it needed 35 PTO HP...as the baler got newer the power requirement upped for user experience.
I run a 630, the oldest model in that line, I used to run it with 42 PTO HP utility, full baler heading uphill 4.5 MPH I had to downshift to keep rpm up.
Example:
(3) ALUMINUM STEP LADDERS (A58374)
(3) ALUMINUM STEP...
2017 CATERPILLAR 259D SKID STEER (A52709)
2017 CATERPILLAR...
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
Bucket (A55973)
Bucket (A55973)
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
FIMCO 200 GALLON FENCE ROW / CATTLE SPRAYER (A52708)
FIMCO 200 GALLON...
