JD4400
/ JD4400 #1
b33b
TX & ME
NH T1520
In looking for a tractor in the 30-40 hp range I have come across a used Deere 4400 but can't find out very much about them. Primary use will be running a chipper and FEL lifting. The older 1070 with a bit more hp actually has higher asking prices, in spite of it's age.
Any drawbacks to the 4400 or the 1070?
Thanks in advance,
Cal
/ JD4400 #2
I do not know what your intended use of the tractor is,IE: General use etc mowing/brushogging/running a tiller,but the 4400 is a nice tractor,32 HP about 28 to 29 HP on the PTO depending if it is a hydro or not. The hydro will reduce your pto HP by 1,because of all of the hydraulics being powered by the engine,but that is nothing.
/ JD4400
Thanks for the 4400 comments, Primarily concerned with running a chipper and loading logs too large to chip. Primarily spruce blow downs and smaller, 4-6" dead trees still standing - and lots of old brush piles to clean up.
Still using a push mower for exercise and a garden tracor when grass is to tall, don't anticipate buying a brush hog, probably a rake and a box blade, perhaps a post hole digger. So I am looking for the most pto hp on a frame that can still get through the woods.
Cal
/ JD4400 #4
The 4400 will do everything you mentioned. I have 1800 hours on mine and have worked the guts out of it,skidding logs,tilling,brushhogging,loader work,post hole drilling,grade work with the back blade. I am satisfied my tractor.If you have any more questions or concerns let me know and I will try to help you. Post a message or pm or email me.
/ JD4400 #5
I own the 4300 and love it. Mine does everything you mentioned and a whole lot more.The 4400 has a few more horse to play with.
2005 Infiniti FX35 AWD SUV (A66738)
2005 Infiniti FX35...
2021 Polaris Sportsman 570 AWD ATV (A66738)
2021 Polaris...
2013 FORD F-150 (A67714)
2013 FORD F-150...
2005 STERLING LT9500 SERIES HYDROVAC (A67714)
2005 STERLING...
2007 JLG 660SJ SKYPOWER TELESCOPIC BOOM LIFT (A65056)
2007 JLG 660SJ...
Location Tampa, FL. Year: 2017 Make: Dodge Model: Durango Vehicle Type: Multipurpose Vehicle (MPV) (A64557)
Location Tampa...
