JD4400
/ JD4400 #1
b33b
TX & ME
NH T1520
In looking for a tractor in the 30-40 hp range I have come across a used Deere 4400 but can't find out very much about them. Primary use will be running a chipper and FEL lifting. The older 1070 with a bit more hp actually has higher asking prices, in spite of it's age.
Any drawbacks to the 4400 or the 1070?
Thanks in advance,
Cal
/ JD4400 #2
I do not know what your intended use of the tractor is,IE: General use etc mowing/brushogging/running a tiller,but the 4400 is a nice tractor,32 HP about 28 to 29 HP on the PTO depending if it is a hydro or not. The hydro will reduce your pto HP by 1,because of all of the hydraulics being powered by the engine,but that is nothing.
/ JD4400
Thanks for the 4400 comments, Primarily concerned with running a chipper and loading logs too large to chip. Primarily spruce blow downs and smaller, 4-6" dead trees still standing - and lots of old brush piles to clean up.
Still using a push mower for exercise and a garden tracor when grass is to tall, don't anticipate buying a brush hog, probably a rake and a box blade, perhaps a post hole digger. So I am looking for the most pto hp on a frame that can still get through the woods.
Cal
/ JD4400 #4
The 4400 will do everything you mentioned. I have 1800 hours on mine and have worked the guts out of it,skidding logs,tilling,brushhogging,loader work,post hole drilling,grade work with the back blade. I am satisfied my tractor.If you have any more questions or concerns let me know and I will try to help you. Post a message or pm or email me.
/ JD4400 #5
I own the 4300 and love it. Mine does everything you mentioned and a whole lot more.The 4400 has a few more horse to play with.
2017 CHEVROLET 5500XD S/A BOX TRUCK (A59914)
2017 CHEVROLET...
10' Sheets of Tin (A64912)
10' Sheets of Tin...
ROOM WITH MISC ITEMS (A67714)
ROOM WITH MISC...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2018 Rotary SM18N001 18,000lb. Hydraulic 4-Post Auto Lift (A66736)
2018 Rotary...
2025 4F2300 Fuel Tank (A64912)
2025 4F2300 Fuel...
