JD4310 J20D hydraulic fluid
   / JD4310 J20D hydraulic fluid #1
arcuriel
Chesterton, IN
John Deere 4310
I have a JD 4310 e-hydro tractor. It is low on hydraulic fluid. I went to TSC to try to locate some and did not have any luck. I found some oil at TSC that said it was the same as J20C, but nothing that was for J20D. According to the manual it can take J20C or J20D, but from my research they are not the same viscosity and are to be used in different climates. Can someone shed some light on the differences? Also, what should I be using? I did some research on the forum, but I am still confused.
I can special order hyd. fluid from TSC for $55 part #127701799, but I need it now and cannot wait.
Traveller Renew Tractor Hydraulic Fluid 5 Gallon at Tractor Supply Co.
   / JD4310 J20D hydraulic fluid #2
From bobistheoilguy.com
Re: Substitute for John Deere Hy-Gard J20D?[Re: Wrehch]*#881598
09/18/07*12:17 AMJoined:*May 2005*
Texas
marco246**
Chevron "Synthetic All-Weather THF" meets JD J20C and J20D specs. Viscosity at 40*C/100*C is 44.7/9.5 cSt.*
Chevron "THF W" meets J20D only. Viscosity at 40*C/100*C is 34.4/7.3 cSt.
   / JD4310 J20D hydraulic fluid #3
Also tsc their "new" Traveller Premium Tractor Hydraulic Fluid 5 Gallon
Says it's good for JD applications
   / JD4310 J20D hydraulic fluid #4
They have 2 one says for J20D and one for J20C depends on weather
any suggestions where to buy this locally, Autozone, Napa, O'Reilly's, Advanced??????
my internet searches aren't giving me any place to purchase.
   / JD4310 J20D hydraulic fluid #6
The traveler brand is tractor supply, the chevron maybe napa or check to see if there is a chevron bulk dealer close
   / JD4310 J20D hydraulic fluid #7
Also napa makes a j20D synthetic just go to napa sight and search for j20
   / JD4310 J20D hydraulic fluid #8
Yep if it's low need to put same oil in
Billy Goat Multi Vacuum (A56860)
Billy Goat Multi...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2010 John Deere 8329R Tractor (A59814)
2010 John Deere...
FORD F-250 CREW CAB TRUCK (A59823)
FORD F-250 CREW...
