JD4300 and 2" wheel spacers on rear wheels.....
   / JD4300 and 2" wheel spacers on rear wheels..... #1
paulcapasso
Connecticut
2000 JD 4300 / 2006 155C
Hello All!
Would like some input on installing 2 inch wheel spacers on my 02 JD4300. Problems? Design ok for it?? Thanks!
   / JD4300 and 2" wheel spacers on rear wheels..... #2
There are tons of threads on the use and brands of wheel spacers. Search is your friend.
Yes the tractor is designed and can handle 2" spacers.
   / JD4300 and 2" wheel spacers on rear wheels..... #3
Before you add spacers, you might get the width you need by reversing the rear tires.
I gained about 2-2.5 inches (per side) by reversing the rims on my 4400 (same tractor as your except for the engine). This was with turf tires, BTW.
In my case, I need more clearance for snow chains...
That's what the manual says. I don't like the valve stems for the rear facing inward since I check the tire pressure every few days. Non Turf tires 19.5 rims. Also did the 1st 10 hr flush this weekend with the Hydro fluid. came out clean. 10 more hours and it's going to be gone through again. It drives and works a lot smoother. Not having issues lifting or lowering loader or 3pt hitch. Filter screen had some shavings on it but from what I can gather this is normal...
WOODS TBW15.40 LOT NUMBER 243 (A53084)
WOODS TBW15.40 LOT...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2020 COLOMBO TM LOT NUMBER 217 (A53084)
2020 COLOMBO TM...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
(6) Bags of Tire Chains (A51573)
(6) Bags of Tire...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53472)
NEW 2024 LOAD...
