JD420 govener set up
/ JD420 govener set up #1
trialsguy
Kansas City Mo. area
YM226D
I have a 420 lawn tractor and I am having a issue with the govenor I think. It pulses preety bad at low rpm, like the govenor is messing up so I thought I would see about the ajustment procedure and check to see if it is adjusted right, although I do suspect the carb is out of adjustment a little bit.
/ JD420 govener set up #4
yep, put a fuel filter in line between the pump and the carb to prevent this from happening again.
Skid Steer Post Auger (A65640)
Skid Steer Post...
Gravely Walk Behind Tractor (A65640)
Gravely Walk...
ALLMAND MAXI LITE 8KW LIGHT TOWER (A65643)
ALLMAND MAXI LITE...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
