JD400 Backhoe valves
   / JD400 Backhoe valves #1
down n dirty
John Deere jd400
Hi all anyone have a rebuild write up on these. They are on a 1968 JD400 backhoe. Thanks. IMG20200229194004.jpegIMG20200229194009.jpeg
   / JD400 Backhoe valves #2
What's the desire to rebuild valves? External oil leaks or some other problem??? JD 400 tech manual should contain info you desire.
Yes these are leaking.
   / JD400 Backhoe valves #4
down n dirty
Second thread now on your JD400.. As you continue with more questions/experiences with the 400, suggest you keep it under one thread if possible. Such as JD400 Backhoe so the members can keep things straight that may help you with your problems.
See that you are from southern Australia, and that does help to understand some of the terms you may use, that are a bit different than ours.
Add that to your profile, and we will look forward to getting to know you and your JD 400.. there are a variety of JD 400's from lawn to ag to industrial and including "vintage".
More pics will help too. Sounds like a fun project to get up and running good.
Thanks been there.
   / JD400 Backhoe valves #7
down n dirty
I agree JD built more than one model of 400's but down n dirty's photo showed his was an industrial model 400
Leaking at spool end or hyd fitting? If leaking at spool then which end or is valve leaking internally?
Leaking at spool. From the top where joystick controls go in. Thanks.
   / JD400 Backhoe valves #9
Does your backhoe have a model # similar to 9250A
   / JD400 Backhoe valves #10
down n dirty
I think a new thread for each problem is a better way to go. With a title that give an idea of the problem, rather than one long thread that jumps from one problem to the next.
Hay Fork (A50860)
Hay Fork (A50860)
2011 Clarke JU4H-UFE0 4 in. Water Pump (A50860)
2011 Clarke...
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
2013 Ford F-150 4x4 Pickup Truck (A48081)
2013 Ford F-150...
