JD3720 Axle leak
/ JD3720 Axle leak #1
jamtuc
Kentucky
John Deere 3720
Left side seems to be leaking at the pivot joint. Right side at the lower seal. I read somewhere that heavy use of front end loader could cause axle leakage. That痴 why one has a front loader, correct? To carry heavy stuff. Anywho is there any permanent fix? I hate duplication of effort.
Thanks in advance guys this is where I always turn to for tractor help. You guys are awesome!:cool2:
/ JD3720 Axle leak
OK folks, Spent 600 dollars to have entire front axle rebuilt. 20 hours later leaking again. Didn't overload it. Is this a common problem and is there a fix?
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
