JD3520 Cab FEL Joystick Lock Not Working
   / JD3520 Cab FEL Joystick Lock Not Working #1
Thowle
Kentucky
John Deere 4066R Cab w/ H180 and 4-in-1 Bucket
The three way toggle push-in/pull-out lock switch below the joystick doesn't do anything on my tractor.
It says it is supposed to lock the joystick, but in all three positions I can still move the loader. Ideas?
   / JD3520 Cab FEL Joystick Lock Not Working #2
You have to remove side panel and tire to adjust the cables at both ends because your joystick is off center. You may have enough adjustment if you just remove your tire
   / JD3520 Cab FEL Joystick Lock Not Working #3
My 4520 is the same way. I found if I "wiggle" the joy stick, the lock will slide in further and engage. There is some free play in the linkage/cable and the lock doesn’t line up perfectly. I'm sure you can adjust it, but I will let my dealer do it when I take it in for the first service.
   / JD3520 Cab FEL Joystick Lock Not Working #4
Hi!,
I am researching a similar problem on my 4066R (I can't unlock the curl function regardless of the position of the locking lever) and I came across this old thread. Were you able to resolve this, and if so, how?
Thank you.
2013 CATERPILLAR 336E L (A58216)
2013 CATERPILLAR...
(2) STAMPED INTERNATIONAL WEIGHTS (4) FORD WEIGHTS (A52708)
(2) STAMPED...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 BMW X3 Sport AWD SUV (A56859)
2009 BMW X3 Sport...
8'x16' METAL TRUCK BED (A52708)
8'x16' METAL TRUCK...
PALLET OF DISHES (A58374)
PALLET OF DISHES...
