Traction JD2320 wider axle
/ JD2320 wider axle #1
Hopster
Deere 2320
Does anyone know if making a wider wheel base on a JD2320 is possible ? I have many steep hills and need more stability. Any manufacturer/kit recommendations would be appreciated.
/ JD2320 wider axle #3
Welcome to TBN:D
Are the wheels set to the wide position now? Yes, you can get wheel spacers if you want, there is lots of discussion on them-search the term "spacers" here in the JD forum.
/ JD2320 wider axle #4
Hi Hopster & All, in my 3120 manual, it gives me 8 different tyre positions ( if u have "Dished" wheels) in my manual its under Service Miscellaneous. when my tractor arrived, i too felt the unit was too unstable, dealer turned wheels around (ie dish outward) then changed the rim attachment to the inside - now my tyres run partly outside the mudguard line, but is much more stable - check what width u can achieve b4 buying spacers - might save u a good few $.
cheers Oz GH
/ JD2320 wider axle
Thanks for all the info. I also found that Unverferth will make hub extensions to a maximum of 8'. Looks like around $500. JD Dealer looking up details now.
2201SFL (A64553)
2201SFL (A64553)
340 GAL WATER TANK (A68842)
340 GAL WATER TANK...
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
FIXED FIFTH WHEEL ATTACHMENT (A67714)
FIXED FIFTH WHEEL...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
