JD2210
/ JD2210 #1
Fastlane
I presently have a JD 455 with 40 loader and 47" snowblower with quick hitch.Dealer offered me a 2210 with fel quick hitch and rear hydralics as I plan to put a woods backhoe on it.My tractor and $4000. is that a decent deal. Would appreciate any advice. /forums/images/graemlins/confused.gif
/ JD2210 #2
Can't tell much from your profile, and regional influences on pricing will vary, but that may be a good deal. How many hours on the 455? Are you planning on keeping the 47 blower on the 2210? What about MMM's?
/ JD2210
The 455 has 724 hours on it...snow blower goes with the tractor keeping 54" blade for 2210..I live in North central PA
/ JD2210 #4
fastlane,
Still not sure about the MMM (mid mount mower) part, but the 2210 should be about $9500, the loader $1500, and the quick hitch $500. So it's like saying your 455 is worth $8000, which may not be that bad of a deal (I know you have more than that into it). You will sure get more performance out of the 210 loader, and you also are gaining 4WD, so it may be worth it.
/ JD2210 #5
Sounds like a great deal. I wasn't aware that you could get a 2210 with rear hydraulics. /forums/images/graemlins/confused.gif
/ JD2210
I should have given more specifics to get a better opinion I guess..here goes my second try..sry guys I am new at this..My JD455 is a 1999 model with 725 hours on it..condition is almost mint..mmm is 3 weeks old it is a 54" mulcher compatible deck..rear tires are loaded with windshield washer fluid..has new wheel weights and chains..has rear weight bar with 6 suitcase weights...40 loader has less then 50 hours use..new in the box 47" 2 stage snowblower with quick hitch..and 54" blade..DEALER wants $4500. and my tractor with everything but blade weights and chains for the 2210.
/ JD2210 #7
fastlane,
So then will the 2210 come with a MMM, and if so, which one? As for the deal, he's probably giving you as much of a discount on the 2210 as he can, or giving you as much trade in for the 455. A year ago I traded in a 10+ year old 425 w/just over 700 hrs on it, 3PH, 54" MMM, and front quik-tach against a 2210. The dealer discounted the 2210 and attachments 16% and gave me $4500 for the trade-in.
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
